  3. encounter : place/preplace buffers next to IO pads
  • Subscribers 92
  • Views 1388
Yemelya
Yemelya over 15 years ago
There are about 600 buffers which should be placed as close as possible to the io pads they are connected to. I set “set_max_capacitance 0” on the relevant nets before placement
> setPlaceMode -timingDriven false -reorderScan false -congEffort high doCongOpt true -modulePlan false -placeIoPins false -wireLenOptEffort high
>placeDesign –noPrePlaceOpt
It has not worked.
What is the recommended flow / solution for such cases?
Thank you.
Boris
  • Kari
    Kari over 15 years ago
     You can use specifyJtag and placeJtag. These steps are run before placeDesign. See the section in the User Guide called:
    Specifying and Placing JTAG and Other Cells Close to the I/Os
  • Yemelya
    Thank you very much! Exactly what I need!
