  3. get wide wire space info by dbcmd
  • Subscribers 94
  • Views 15362
grayq
grayq over 16 years ago
Hi  ,
In  tech lef  file  ,   inculding  the following lines:
    SPACING 0.420 ;
    SPACING 0.600 RANGE 10.001 200.0 ;
    SPACING 0.600 RANGE 10.001 200.0 INFLUENCE 1.0 ;
 we can  get  SPACING 0.420  by dbLayerMinSpace
but  how to  get  the other  space  info  ,  can you  teach  me?
 another  question:
dbGet head.layers.spacingTables ,  why  this  command  get  0x0,
gray
  • BobD
    BobD over 16 years ago
    I think you're using the command correctly. "dbGet head.layers.spacingTables" shouldn't return 0x0.
    I just tried using 9.1.USR1 and 8.1.USR3 and it working as desired.  What version are you using?  If you're using 8.1.USR3 or newer perhaps you could file a service request or provide more information.
    Bob
  • grayq
    Hi  Bob,
     Thanks for  your  help.
    My version is  9.1.USR1.  I know  what  you  said.
    When  using  the following  lef  file ,  tool   working as desired:
       SPACINGTABLE
      PARALLELRUNLENGTH     0.00    1.00    1.50    4.50
      WIDTH    0.00         0.20    0.20    0.20    0.20
      WIDTH    0.39         0.20    0.24    0.24    0.24
      WIDTH    1.50         0.20    0.24    0.50    0.50
      WIDTH    4.50         0.20    0.24    0.50    1.50 ;
    But  ,  I  have  only  this  lef  file  ,  how  to  do ?
        SPACING 0.420 ;
    Thanks again
    gray
