  3. Problem generating cdb views with make_cdb Version 6.1
  • Subscribers 94
  • Views 16982
AnnaP
AnnaP over 16 years ago
Hi ,
 I have problem generating cdb views. There are multiple Warnings:
1. WARNING:(SI-2167) The -synlib option of the generate_cell_lib command is
    obsolete. To load Synopsys .lib files, use the read_dotlib command before
    generate_cell_lib.
 I have added the read_dotlib command before generate_cell_lib but warining still appears.
2. Some warnings comping from the Spice logic file used -- I assume these can be ignored
3.And finally the cdb views are not generated with the following status:
==> ERROR:   Memory allocation failed <TECHLIB-253>.
ERROR:(SI-0511) Signal 6 Caught.                                    [make_cdb]
Runtime : 217.46u 7585.2s 36230w
Heap Growth : 31603.3MB
Please help and let me know if any additional info is needed.
    Moved to the Digital Implementation Forum because it's more likely to get an answer there.
  • Kari
    Kari over 16 years ago
     Hi Anna,
    For the memory crash (#3), run make_cdb -64.
    For the synlib warning (#1), did you remove that command from your command file?
    - Kari
  • AnnaP
    Hi Kari,
    -64 option is on. It does not help.
    I have removed the -synlib and add the read_dotlib. But I see errors:
    make_cdb: read_dotlib ../../liberty/logic_synth/ts45nkkssst_ttdb0p9v25c.lib
        Info:    No function defined for cell 'STN_TIEDIN_1'. The cell will only be
                 used for analysis. <TECHLIB-302>.
        Info:    Library 'ts45nkkssst_ttdb0p9v25c' was loaded from file '/auto/
                 scratch2/annap/fujitsu/58448/ts45nkksssta02/cdb/make_ttdb0p9v25c/..
                 /../liberty/logic_synth/ts45nkkssst_ttdb0p9v25c.lib' <TCLCMD-701>.
    make_cdb: generate_cell_lib  \
        -vdd { VDD } -gnd { VSS } \
        -maxsize 500 \
        -file_list { ts45nkkssst_ttdb0p9v25c_main.sp ts45nkkssst.spx } \
        -file ts45nkkssst_ttdb0p9v25c.cdb
    generate_cell_lib WARNING: Nothing to characterize; ... exiting
        while executing
    "error "$pref WARNING: Nothing to characterize; ... exiting""
        (procedure "generate_cell_lib" line 339)
        invoked from within
    "generate_cell_lib  \
        -maxsize 500 \
        -file..."
    Runtime : 11.11u 0.21s 15w
  • AnnaP
    Hi Kari,
        -maxsize 500 \
        while executing
        invoked from within
        -maxsize 500 \
        -file..."
  • Kari
     Looks like you're missing the -cell_list parameter of generate_cell_lib.
  • NigH
    NigH over 16 years ago
    Afer running my script within make_cdb 7.1, I have the follow error:
     process_constraint: Finished in 0 seconds
    Assertion `_r >= 0.0' failed
    cmfatal: ERROR: Stopped in file resrdx.cxx line 210
    ERROR:(E_FATAL_ERROR) The program has a fatal error and is being terminated.
        Fix the ERROR and WARNING messages in the log file and re-run    [cmfatal]
    ERROR:(SI-0515) Internal Error : Cannot continue execution .. exiting [make_cdb]
    Is this a bug in the tool?
