  3. Change the orientation of an instance in Encounter
  • Subscribers 96
  • Views 18806
Greatrebel
Greatrebel over 16 years ago
Hi All,
I use the command addInst to add a cell into my P&R design like below
addInst -cell INTAMP2S -inst opamp1 -loc 500 500 -ori MX90
But I got a info: Instance opamp1 is placed sideway.  Reset orientationto to R0.
It seems like I can only change the orientation of this instance as R0,  R180, MX and MY which are landscape styles (horizontally), but not for R90, R270, MX90 and MY90 which are portrait styles (vertically). Once I tried to change to portrait style, it will be reset to R0.
Anyway can make it change to R90, R270, MX90 and MY90?
Thanks in advance
  • Alex Soyer
    Alex Soyer over 16 years ago
    You need to change the input LEF of INTAMP2S:
    SYMMETRY X Y R90
    Alex
  • Greatrebel
    Hi Alex
    Thank you very much for your help
  • Kari
    Kari over 16 years ago
     You may want to double-check that those orientations are allowed. The LEF may have been coded that way for a reason. For example, in some SOI processes, all the poly lines have to be in the same direction, so RAMs are not allowed to be rotated R90, R270, etc. Just wanted to mention that.
  • Greatrebel
     Hi Kari,
     Thank you very much
