  3. Some warnings during NanoRoute
  • Subscribers 94
  • Views 15643
Greatrebel
Greatrebel over 16 years ago
 HiAll,
When I run Nanoroute with globalDetailRoute in Encounter, I got a few warnings like below
#WARNING (NRDB-733) PIN Y in CELL_VIEW top,init does not have physical port
#WARNING (NRDB-733) PIN acc_out[0] in CELL_VIEW top,init does not have physical port
These pins are chip pins on the top module. The rest of pins are fine. I think I treat these pins and other pins same in my code and script. So I have no idea about what these warnings mean.
 Any help will be appreciated
  • Kari
    Kari over 16 years ago
     The warning is saying that these pins do not have a physical shape for the router to connect to. In the design browser, if you select these terms and then zoom to selected, what do you see?
  • Greatrebel
     Hi Kari,
    I check those pins. They are either in triangle or diamond shape depends on input/output or inout. For those output pins, they are attached to the PAD pins of IO pads (no wire connection, they are just linked together, since PAD pins are facing outside of this chip). For some pins which are from an analog module, their corresponding analog IO pads having two instance pin areas facing to the core (those ananlog IOs only have one pin called AIO), the AIO pins are attached together with those analog pins, shown in the one of the two pin areas. The router only route one wire connection from each pin of analog module to the pin area without AIO on it. But  the information from query (next to the Q button) shows both of the pin areas are connected to the analog pins.
    I do not know whehter I describe the situation clearly.
    Thanks a lot
  • Kari
     Is it possible to post a picture of this? It would help me understand better.
