  3. setup violation
  • Subscribers 94
  • Views 15366
setup violation
PhilBzh
PhilBzh over 16 years ago
 I can't solve a problem with a lot of setup violation. Even if I run optDesign I still have the same huge number of setup violation.
In my, .sdc, I only create the clock and define its period and waveform. Is it enouth ?
I already worked on my .ctsch and it seems to be good.
Has anyone some ideas to solve this problem ?
Phil
  • Kari
    Kari over 16 years ago
     Having just a clock definition in the sdc file should work, but for realistic timing analysis, you really should have more than that. At the least, I would think you'd need input/output delays and drive cell assertions. Check out the following blog series for a great tutorial on creating timing constraints:
    http://www.cadence.com/Community/blogs/di/archive/2009/02/09/constraint-construction-what-s-it-s-function-part-1-of-4.aspx
    http://www.cadence.com/Community/blogs/di/archive/2009/02/18/constraint-construction-what-s-it-s-function-part-2-of-4.aspx
    http://www.cadence.com/Community/blogs/di/archive/2009/03/06/constraint-construction-what-s-its-function-part-3-of-4.aspx
    http://www.cadence.com/Community/blogs/di/archive/2009/04/09/constraint-construction-what-s-its-function-part-4-of-4.aspx
    If you post the timing report for your worst path, I might be able to tell a few things.
    - Kari
