  3. Re: connecting a power pad to a mcaro pin
  • Subscribers 94
  • Views 14731
gops
gops over 16 years ago
Hi Kari, thank you very much for the reply.I hav already checked the LEF it is ok.I understood the problem but still i don't know how to solve it except going for manual routing. The connection is not happening because I don't have any ring or stripe for the pad and the pin to get connected.Actualy i don't need a ring since it is a connection from a single pad to a macro pin.In short, i have defined a global net VPP and connectd the pad pin and macro pin to the global net.I don't have a stripe or ring for VPP since it is just required for a macro.Can you tell me how i can connect these pins now using sroute. Thanks gopakumar > > Check the LEF for the IO pad. The core-facing VPP pin needs to be CLASS > CORE, like this example: > > PIN VDD > USE POWER ; > DIRECTION INOUT ; > PORT > CLASS CORE ; > LAYER... > RECT.... etc. > > > -- > View this message online at: > www.cadence.com/.../65288.aspx > -- > You received this email because you subscribed to notifications for the > Cadence Digital Implementation Forum. To unsubscribe, log in, go to > forums, and change your forum subscriptions. > > www.cadence.com/.../ForumSubscriptions.aspx ----------------------------------------- This email was sent using SquirrelMail. "Webmail for nuts!" http://squirrelmail.org/ ______________________________________ Scanned and protected by Email scanner
  • Kari
    Kari over 16 years ago
     I think your theory is correct - sroute is looking for a ring or stripe. If this is just one connection, we would typically do this by hand. Is this a really difficult connection to draw by hand?
