  3. Validate CDB noise model file
  • Subscribers 94
  • Views 16723
deeps
deeps over 16 years ago
Hi All,
 I am trying to create a .cdb file using make_cdb utility for some of the custom cells.
      Can some one suggest me the best way to validate the created .cdb file.
 regards
deepak.
  • NigH
    NigH over 16 years ago
    Hi deepak,
    Create a text version of the cdb as well and then validate using this
    command:
    validate_cell_lib -cdb cdb/typ/tsl18fs120.cdb.txt
    Regards
    Nigel
    On Thu, 2010-07-01 at 05:51 -0700, deeps wrote:
    > Hi All,
    > the custom cells.
    > created .cdb file.
    > regards
    > deepak.
    > View this message online at:
    > https://www.cadence.com:443/Community/forums/p/16116/241257.aspx#241257
    > You received this email because you subscribed to notifications for
    > the Cadence Digital Implementation Forum. To unsubscribe, log in, go
    > to forums, and change your forum subscriptions.
    > http://www.cadence.com/community/forums/ForumSubscriptions.aspx
    Nigel Hughes
    AnaFocus Digital Design
    Av. Isaac Newton s/n,
    Pabellón de Italia, 7ª Planta, Ático
    Parque Tecnológico Isla de la Cartuja
    41092 Sevilla, España
    Fax: +34 954 08 12 42
    E-Mail: nigel@anafocus.com
    Web: http://www.anafocus.com
  • Kari
    Kari over 16 years ago
     You can also include this line at the end of your make_cdb script:
    validate_cell_lib -cdb myLib.cdB
  • deeps
     Hi Kari & Nigel,
            Thanks for your suggestions, i went through the makecdb.pdf and also had used the same "validate_cell_lib" command, But i wanted to know should this be enough or its better we do some kind of spice simulations to find out the quality of the data genrated from make_cdb utility (i am not sure how this can be done, but just had a thought).
    deepak.
