  3. an GDS import issue of Virtuoso
  • Subscribers 92
  • Views 13480
Greatrebel
Greatrebel over 15 years ago
 Hi all,
I use Encounter to export a gds and then stream the gds into Virtuoso. After I imported encounter generated gds into Virtuoso, I found beside the top cell, there are about one hundred cells generated, they are called top_VIAxx (xx is a numeral). Actually I found that all top_VIAxx cells shown in virtuoso were those via cells manually added in encounter after automic PnR for correcting some drc errors. I am wondering why these via cells were not merged into the top cell when imported into virtuoso?
Can anyone give me a help?
Thanks in advanced
  • Kari
    Kari over 15 years ago
     I think vias are considered as instances in Virtuoso. If your design has a via that is nor already defined in your Virtuoso tech library, it will be created as a cell along with your top cell when you stream in. This is normal.
