  3. problem in loading partitions
  • Subscribers 94
  • Views 15511
spach
spach over 16 years ago
hi,
       I have a database with partition, ptn pins when I load .dat it is showing all info.
       But when I am loading only conf & .fp it is not showing the partitions.
       I want change already specified ptn pinlayer (layers allowed for ptn pins) in .fp under HierarchicalPartitions and the same chages should reflect when i load it.
        can one please help me on chaging the ptn properties maniually by editing .fp not using GUI
suresh
  • Kari
    Kari over 16 years ago
     Did you rerun specifyPartition after you made the changes?
  • spach
    The partitioned r already defined. After the changes I didn't specify partition. I simply saved the DB.
    suresh
  • Kari
     Were you able to solve your issue? If not, can you be more specific about what you're trying to do? I can't tell if you're editing the FP file and your changes are not showing up, or if you're trying some other way.
