  3. set_dont_use/setDontUse
  • Subscribers 92
  • Views 4580
prathima
prathima over 15 years ago
Tool Version: Encounter 8.1.
On my design, I am using set_dont_use for setting and unsetting the dont use property on lib cells.
set_dont_use [get_lib_cells *] true
set_dont_use [get_lib_cells <xyz list>] false
This doesn't seem to have any effect on the "optDesign -hold", though the "get_property [get_lib_cell <xyz>] is_dont_use" reports correctly.
Whereas,
setDontUse [get_lib_cells <xyz_list>] false
is understood correctly by the "optDesign" command. But this command doesn't change the "is_dont_use" property on the lib cell.
Is this difference in the commands expected? Also, is there a way to report the dont_use property set using setDontUse command?
Regards,Prathima
  • BobD
    BobD over 15 years ago
    Sorry you're having trouble with this issue.  I see the same behavior here on my end (specifically in terms of setDontUse settings not being accurately reflected by get_property is_dont_use) and there is an existing bug report open for this issue.  Let me check with our developers on a timeline for when this is going to be repaired.
    In the mean time, I believe setDontUse/reportDontUse is the preferred way of managing these markings for optimization purposes.
    Hope this helps,
    Bob
  • prathima
    Thanks, Bob.
    Regards, Prathima
