  3. How to identify clock network objects in the design?
  • Subscribers 92
  • Views 15366
Rajesh Vembu
Rajesh Vembu over 15 years ago
How to determine all the objects in the propagation path of clock? This would include clock gating elements, buffers/inverters, flops, latches, macros...
  • BobD
    BobD over 15 years ago
    Graphically we have this functionality under "Clock->Analyze Clock Tree".
    Programatically, what I see a lot of people doing is tracing the clock network, writing it to a file and then parsing the file for the information they're looking for.  For example:
    ckSynthesis -clk DTMF_INST/TEST_CONTROL_INST/i_150/Y -check -trace DTMF_CHIP.cts_trace -forceReconvergent -breakLoop
    Hope this helps,
    Bob
  • Rajesh Vembu
     Hi Bob,
    Thanks for the response. We currently follow the method you suggest.
    I was hoping if we can query it using "get_attribute". That would be a very good option.
    Example :
    The clock_network_pins attribute returns all pins that are in the clock tree of the specified clock.
    get_attribute  [get_clocks clock_name]  clock_network_pins
    Regards
    Rajesh
  • BobD
    Hi Rajesh,
    "get_attributes [get_clocks clock_name] clock_network_pins" does work for clocks in the timing domain but as you know from a CTS perspective there isn't necessarily alignment between clocks that originate from SDC and those that we as users define as part of a clock tree spec file.  I'm not aware of a way to programmatically query CTS clocks though it's something that would be useful.
    -Bob
