  3. Spice Models in Celtic Analysis
  • Subscribers 93
  • Views 15475
archive over 18 years ago
Hi, How can we generate spice models (CMOS device - models) in order to run make_cdb for celtic Analysis. What is the importance of spice models in noise library chracterisation. Best Regards Sandeep
Originally posted in cdnusers.org by sandeepv
    Spice models depict the I-V relationship of various cells.It is used to compute the holding resistance.Lower the value of holding resistance lesser will be the impact of functional noise.
    Originally posted in cdnusers.org by abhiroy03
    Hi you can use calibre to generate spice (*.sp) from GDS II . the Calibre Utility name is known as lce ( which is used in LVS ) .
    Please find the command to extract
    calibre -spice CHIP.sp -hcell HCELL cmosx_top.lce_rules > log.lce
    NOTE : i) Hcell is optional
    ii) in rule file you will give the location of your GDS II path for corresponding spice you would like to extract.
    Mohan
    Originally posted in cdnusers.org by mohanch007
