  3. how to move FTerms
  • Subscribers 94
  • Views 14962
how to move FTerms
Nataraja G
Nataraja G over 16 years ago
my requirement is to move selected pins Fterms (tile pins) , to a specified offset
this is what i have done
set selectedList [dbGet selected] ;# list of selected objects
#going into a loop and chaging the positions using
dbSetFTermLoc ftermPtr x y
But theirs a catch ! for tile's along with PIN , we have STRIPBOX (a small metal peice which has been pushed down by integration team) , when im  changing the PIN position this metal peice isnt moving !!!
dbGet selected.box ---- this is giving the position of that metal peice , then i tryed
dbSet selected.box $newPositionCoordinates ----- this isnt working !!!
So, Here are my questions
a)Can we change Pin positions using dbGet or even get the position of selected pins
b)how to move this stripbox , dbInfoStripBox stripbox  has the information but im not able to edit :)
c)how to move any object irrespective of is type (dbObjType)
  • BobD
    BobD over 16 years ago
    Great question.
    I've gotten caught up in this in the past myself.  IO pins consist of a logical "triangular" marker and associated physical geometries.  Some lower-level db commands don't take care of updating all the necessary geometries and it sounds like that's what's bogging you down.
    The most productized way to move IO pins around is through Edit->Pin Editor which resolves to the editPin command.  If you wanted to use editPin to space the selected pins out along the top boundary starting at x=10 and spacing them out by 20 microns you could do something like this:
    #first, capture the top coordinate of the design:
    encounter 59> set y [lindex [lindex [dbGet top.fplan.box] 0] 3]
    231.84
    #then call editPin on the selected pin names:
    encounter 60> editPin -pin [dbGet selected.name] -spreadType START -side TOP -layer 2 -start 10 $y -spacing 20
    Successfully spread [3] pins.
    You could also mimic the spreading functionality yourself by calling editPin -assign which defines an explicit location:
    set x 10
    foreach term [dbGet selected] {
      editPin -pin [dbGet $term.name] -assign $x $y
      set x [expr $x + 20]
    In general, you should also be able to use dbSet to set the .pt of each selected term (or other dbGet object type that is settable according to what dbGet <obj>.?h says) but in testing here I notice that this approach suffers from the same limitation as you're seeing- that the geometry of the pin isn't updated correctly after the move.  I'll file a bug against that- thanks for raising my awareness of this issue.
    Hope this helps,
    Bob
