  3. Estimating power stripe width
  • Subscribers 93
  • Views 15386
archive over 18 years ago
Hi All, Can Anyone guide me how to estimate the width of power stripe . Regards, KVB
Originally posted in cdnusers.org by viswanadhbabu
    Hi KVB,
    I just posted this to another thread:
    As for power stripe widths, these are usually back-of-the-envelope calculations. If you have a wirebond design, you can probably work up a spreadsheet that has the total expected power of the design, the widths and spacings of the stripes, voltage, design size, resistivity of the layers, and calculate a voltage drop. Then keep adjusting the width and spacing numbers until you get an acceptable drop, and start with that. Maybe add a fudge factor somewhere just to err on the conservative side. For flip chips, the calculations are not so easy, but you need much less striping in a flip-chip anyway since power comes down from bumps all over the core. So pick something to start with and do an IR analysis as early as possible.
    Hope that helps a bit,
    - Kari
    Originally posted in cdnusers.org by Kari
