  3. global net connections
  • Subscribers 95
  • Views 16615
bharat kurra
bharat kurra over 16 years ago
how to get hard macro's VDD and VSS pin names
so,that i can use them in global net connections
i have extrated these names from macro LEF's using a script but is there any db command to get them directly
  • admin
    admin over 16 years ago
    anyone knows the answer
  • wally1
    wally1 over 16 years ago
    The following Cadence Online Support solution provides a script for getting the power pins of instances. Does this provide what you need? The dbGet commands used in the script show how to get at the power pins of a cell from the instance name. You could do something similar if you want to do it for specific cells.
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11539508
     - Brian
