  3. special net not being routed when sroute ran
  • Subscribers 94
  • Views 16817
diablo
diablo over 16 years ago
 Hi all,
I am trying to route special net "bdpd_5v" using sroute. However, sroute is not routing the net.
This bdpd_5v signal connects output pin in one of the IO cell  to input pin 'BDPD_5V' of rest of the IO cell. This signal detecs the presence of power in IO cell and prevent backdrive leakage on absence of power.
I have set this signal  as special net
 "setnet -net bdpd_5v     -type special -setTermSpecial"
Then used 'sroute' with following options
sroute -connect { blockPin padPin padRing corePin floatingStripe }
-layerChangeRange { 1 6 } -blockPinTarget { nearestRingStripe
nearestTarget } -padPinPortConnect { allPort oneGeom }
-checkAlignedSecondaryPin 1 -blockPin all -allowJogging 1
-crossoverViaBottomLayer 1 -allowLayerChange 1 -targetViaTopLayer 6
-crossoverViaTopLayer 6 -targetViaBottomLayer 1
The net was not routed by sroute. I had also connected the net to the global net using
"globalNetConnect bdpd_5v    -type net -net bdpd_5v -all -verbose"
and ran 'sroute' with the same option as above. This net is still not routed.
Any suggestions?
The reason I wanted to use sroute for this net is while routing this net through nanoroute, it is buffering this net inside core using standard cells which is at 1.8V and this net is at 5V.
Thanks a lot for your time.
  • Kari
    Kari over 16 years ago
     This isn't the kind of net sroute is meant for. If all you want to do is have this net routed without any buffering, then it can remain a regular net and nanoroute can route it, but your constraints file (SDC) must list this net as "set_dont_touch". Then optDesign will not buffer the net.
    set_dont_touch  [get_nets {bdpd_5v}]
  • diablo
     Thanks Kari. I already got the same response from Cadence support a while back and it does solve the issue and prevent the net from routing inside the digital core. If i want to prevent all analog nets from being routed inside digital core in a mixed signal design chip, what flow would you recommend. Do i have to set dont touch for all the analog nets in our chip to prevent the nanoroute to route it through any buffer ? Thanks again for your time.
  • Kari
     You're kind of talking about two different things.
     1. You don't want any buffers added on these nets. The optDesign command is what adds the buffers, not nanoRoute. You would need a set_dont_touch on all of the nets that you don't want to buffer. That way, optDesign will leave them alone.
    2. You don't want these nets to route in the core area. Just because there are no buffers added to the nets, that does not guarantee that the net won't possibly veer into the core area if routing resources on the edge of the chip are tight. Maybe your main goal is just to avoid buffering the nets, in which case taking care of the first issue is enough. But if you don't want any of these nets' wires inside the core area, you would have to use routing blockage, route these nets first, then remove the routing blockage to route the rest of your design.
    Let me know if I misunderstood your intent.
  • diablo
     Thanks Kari. My intent is just to avoid buffering the nets because when those analog nets, which are at 5v domain, get buffered it is incorrectly connected to 1.8V standard cells. I just want to prevent this from happening. I know i could use CPF and define different power domain area but currently we dont have license to use CPF and level shifter insertion, so i am figuring out different flow to avoid the 5V net  to be routed through 1.8V standard cells. I think 'set_dont_touch' on all the analog nets will work for me.
  • Kari
     Yep - set_dont_touch on those nets will achieve what you want!
