  3. Reg data type -stream map file
  • Subscribers 93
  • Views 1435
archive over 18 years ago
Hi all, Can anyone explain about the parameter "data type " in the stream map file . Thanks , KVB
Originally posted in cdnusers.org by viswanadhbabu
    Hi KVB,
    In GDSII, every layer has 2 numbers that make up the stream information: the layer number and datatype. In most cases, for major layers, the datatype is usually 0. For example, metal1 drawing would be layer 31, datatype 0. Designers can use the datatypes to organize things how they want. For example, metal1 wires being 31:0, but metal1 fill being layer 31, datatype 5. You will see lots of different usages across different technologies, vendors, etc.
    Hope that helps,
    - Kari
    Originally posted in cdnusers.org by Kari
