  3. generating stream map file
  • Subscribers 93
  • Views 15296
archive over 18 years ago
Hi all , Can anyone explain me , the different ways of generating stream map file. Thanks , KVB
Originally posted in cdnusers.org by viswanadhbabu
    The custom layout folks should have a layer map file. We started with this and hacked the stream map fiile.
    Each layer is associated with layer numbers.
    It has the following syntax:
    M1 NET,SPNET,VIA,PIN AA BB
    M1 FILL AA BB
    V1 VIA CC DD
    Repeat this for all your metal/via layers. The numbers (AA BB) and (CC DD) can be found in the custom layout stream map file.
    If you want text labels add the following as well :
    NAME M1/PIN AA BB
    This is also documented in
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/soceUG/soceUG6.1.4/design.html#1073278
    Sanjay
    Originally posted in cdnusers.org by ssunder@sioptical.com
