  3. How to implement dual threshold voltage in a circuit?
  • Subscribers 94
  • Views 16978
Preetisudha
Preetisudha over 16 years ago
Hi all, I am working with cadence.... I want to know that how to implement dual Vth in a circuit.... Please answer me.... Thanking you.... Preetisudha................
  • Kari
    Kari over 16 years ago
     Can you be more specific about what you're trying to do? If you're asking "How do I work with multi-VT libraries in Encounter", then that's pretty easy. Just load in the .lib and LEF files of the different VT cells and Encounter can use them. If you do a leakage opt, for example, Encounter will know to swap out the leaky VT cells for less-leaky ones without breaking timing.
  • Dineshvv
    Dineshvv over 15 years ago
     Hi,,
     i have seen ur post. U have been posted it a year ago.. I think u might have done the thing using dual threshold vge technique.. Am doing project in the same topic. I ll send my base paper along with this msg. pls go thro it and give me idea asap. Am having cadence tool with me.
    Effectiveness Analysis ofLow Power Technique of
    Dynamic Logic under Temperature and Process
    Variations
    Jinhui Wang*, Wuchen Wu, Na Gong, Wang Zhang, and Ligang Hou
    Abstract - Using multiple-parameter Monte Carlo method,
    the effectiveness ofthe dual threshold voltage technique (DTV)
    in low power domino logic design is analyzed. Simulation
    results indicate that under significant temperature and
    process variations, DTV is still highly effective to reduce the
    total leakage and active power consumption for domino gates
    with speed loss. Also, regarding power and delay
    characteristics, different structure domino gates with DTV
    have different robustness against the temperature and process
    variation',
    Index Terms - domino gate, temperature and process
    variation, effectiveness.
    I. INTRODUCTION
    Dynamic circuits, in particular domino gates are often
    applied in high speed digital circuits due to their fast
    evaluation and small area merits [1]-[3]. However, as
    technology scales down, the leakage power of domino logic
    increases exponentially with the scaling of the threshold
    voltage (Vt) and gate oxide thickness (tax} By the sub-65nm
    generation, leakage power may constitute as much as 50
    percent of the total power consumption [4], [5].
    The dual threshold voltage technique (DTV) [6] is one of
    most popular techniques to suppress leakage power. However,
    as the technology scales down below 65 nm node, the
    increasing die-to-die and with-in chip variations bring a great
    challenge to low power techniques, including DTV. Two main
    contributors to variations are changes in process parameters
    and changes in operating temperatures. Also, the exponential
    relation between leakage current and temperature makes the
    effect of process variations vary at different temperature.
    Therefore, there exists the need to investigate the
    effectiveness of DTV under process and temperature
    variations to help designers judge if the DTV application in
    circuits could meet the frequency-leakage requirements in
    sub-65 nm era. Many researchers have utilized Monte Carlo
    method to analyze the effectiveness of DVT with variations,
    but they still could not solve the problem completely. Some of
    them only focus on one variation and ignore the relations of
    two variations [7]. Others analyze process variations only
    This work was supported in part by the PhD Student Innovation Program
    of Beijing University of Technology under Grant No. bcx-2009-015.
    Jinhui Wang, Wuchen Wu, Ligang Hou, and Wang Zhang are with VLSI
    & System Lab, Beijing University of Technology, Beijing 100022, China
    (Tel:+86-1067391638 e-mail: wangjinhui888@ yahoo.com.cn).
    Na Gong is with College of Electronic and Info Engineering, Hebei
    University, Baoding, 071002, China (e-mail: nagong_china@yahoo.com).
    978-1-4244-3870-9/09/$25.00 ©2009 IEEE
    1236
    under worse case temperature and fail to consider the uniform
    change of temperature in practice [4], [8]. In this paper,
    utilizing multiple-parameter Monte Carlo method, the
    effectiveness of DTV in low power domino logic is analyzed
    at the presence of simultaneous variations of process and
    temperature.
    II. DYNAMIC CIRCUITS WITH DTV
    DTV could suppress the leakage power efficiently and
    therefore it has been applied widely in VLSI design [6]. As
    can be seen from Fig.l, taking the domino OR gates with
    DTV as an example, the critical signal transitions determining
    the domino circuit delay occur along the evaluation path. In a
    dual V, domino circuit, therefore, all of the transistors,
    activated during the evaluation phase (Nclk, Nl ......Nn, Pr),
    have a low V, Alternatively, the precharge/predischarge phase
    transitions (PI, P2, Nr) are not critical for the performance of
    a domino circuit and they are high V, transistors [9]. It is
    operated as follows. In the precharge phase, the clock is set
    low. PI is turned on. And the evaluation phase begins when
    the clock is set high. PI is cut off. Provided that the necessary
    input combination to discharge the evaluation node is applied,
    the circuit evaluates and the dynamic node is discharged to
    ground. Otherwise, the high state of the dynamic node will be
    preserved until the following precharge phase [10].
    In the idle stage, the leakage power of domino circuits is
    produced by leakage current which is dominated by the subthreshold
    leakage current, which can be expressed by equation
    (1) [11]. In the active stage, the active power of domino
    circuits also contains two parts: the dynamic switching power
    and the leakage power.
    I = Weff
    q£SiNch V2 {VgS
    - ~ J(l- (- Vds JJ (1) sub Ueff T ex exp
    L~ 2$s n~ ~
    where ueffi Weffi Leffi e sis Nch, C/Js» and VT are effective carrier
    mobility, effective channel width, effective channel length,
    thermal voltage, permittivity of silicon, effective channel
    doping, surface potential and sub-threshold swing,
    respectively. From (1), it can be seen that the sub-threshold
    leakage current decreases exponentially with the increasing of
    V, Thus, DTV can lower both the leakage and active power.
    III. TEMPERATURE AND PROCESS VARIATIONS
    Process variations occur due to proximity effects in
    photolithography, non-uniform conditions during deposition,
    random dopant fluctuation, etc. [12]. These cause fluctuations
    in parameters such as channel length, width, oxide thickness,
    Vdd
    Vdd
    Gn
    Vdd
    r---~r=rC---l
    : I
    : Low Vt device : i 4[~I[ l I PU,1<~ll"l Input_~I"'I'" , \
    I
    I H. h II ~ - Nl - Nn ,.
    output l 19 Vt device: \,v-~; 1J -J -_
    II Nr i "---""\ :---II N~ik--------d~~amiC
    : ',...__-,' : c lock node
    : Pull-down :
    I I
    : ~~_t!.~:r.:~ ]
    (a) (b)
    Fig.l Domino OR gates (a) domino gate with Low Vt (b) domino gate with dual Vt
    Gn
    IV. MONTE CARLO ANALYSIS
    In this section, a quantitative analysis is provided to
    investigate the effectiveness of DTV in suppressing the power
    consumption of domino gates under temperature and process
    fluctuations. Domino circuits with different structures of the
    pull-down networks (PDN), such as 2-input, 4-input, 8-input,
    and 16-input domino OR gate (OR2, OR4, OR8, and OR16,
    respectively), 2-input and 8-input domino AND gates (AND2
    and AND8), 2-bit and 16-bit domino multiplexer (MUX2 and
    Vt (T) = Vt (To)+(KT1 + KT1L + VbSefJKT2J X (~-lJ (4)
    i; To
    PMOS:
    ~(T) =Vt(To)-(KT1+ KT1L + VbsefJKT2JX(~-lJ(5)
    LefJ To
    u.g(T) = [u{kf]- (6)
    {I + (Vg""ff 7:).:~(T))' Ub(T) + (uJr)vb"ff +Uam{ Vg"'ff7:x:~(T))} ~1
    where KT1, KTlL, KT2, Vbsejfi u; Ute, TOXE, u; u; o; To,
    and T are the temperature coefficient for threshold voltage,
    channel length dependence of the temperature coefficient for
    threshold voltage, body-bias coefficient of threshold voltage
    temperature effect, effective substrate bias voltage, mobility at
    the reference temperature, mobility temperature exponent,
    electrical gate-oxide thickness, first order mobility
    degradation coefficient, second order mobility degradation
    coefficient, body effect of mobility degradation coefficient,
    reference temperature, and the operating temperature,
    respectively. KT1, KT1L, and KT2, are constant empirical
    parameters while Ua, Ub, and Ui; are temperature dependent.
    (1), (4), (5), and (6) indicate that temperature fluctuation lead
    the variation ofVt which determines the delay and the leakage
    of the circuits.
    45nm
    O.22V O.35V
    -O.22V -O.35V
    O.8V O.8V
    TABLE I
    PARAMETER OF DEVICES
    Technology Node
    NMOS threshold voltage
    PMOS threshold voltage
    Supply voltage
    as well as dopant concentrations, and result in variations in V,
    which determines the delay and the leakage of the circuits.
    Among the variations in transistor parameters, variations in
    gate length and threshold voltage are found to have the most
    significant impacts on circuit performance and power
    consumption [7]. The standard deviation of the intrinsic
    threshold voltage for long channel devices is analytically
    modeled as:
    (J"~ =(!LJ NchWDEP (2)
    tox 3WL
    where q is the charge, tox is the gate oxide capacitance, Nch is
    the weighted doping concentration, WDEP is the channel
    depletion width, and Wand L are the channel width and gate
    length, respectively. This equation is derived for long channel
    devices which do not exhibit short channel effects. As shown
    in equation (2), the variation in threshold is caused by the
    doping un-uniformity and is proportional to the square root of
    doping concentration and inversely proportional to the square
    root of device gate length and channel width.
    In nanometer technologies, the shorter device gate length
    reduces the effective threshold voltage to
    ~h = ~hO - f1~h (~h _roll_ off)- f1~h(DIBL) (3)
    where Voo is the intrinsic threshold voltage, L1
    Vth(Vth _roll_off) and L1 Vth(DIBL) are the drop in threshold
    voltage due to short channel effect and DIBL, respectively.
    The relation between the gate length and threshold roll-off and
    DIBL is exponential and thus when there are variations in gate
    length, the net effect is increased variation in threshold
    voltage.
    Changes in the operating temperature occur due to power
    dissipation in the form of heat. On-chip thermal variations
    have a significant bearing on the mobility of electrons and
    holes, as well as the threshold voltage of the devices. An
    increase in the operating temperature causes the mobility to
    decrease, thereby decreasing the on-current, which, in turn,
    can reduce the speed of the circuit. Further, elevated
    temperatures also lead to an increase in the leakage current
    [13]. The impact of temperature fluctuations on the leakage
    current and V t in a MOSFET is identified utilizing BSIM4
    MOSFET equations. v, and ueffofa MOSFET are [14]
    NMOS:
    1237
    t 0.5
    ox (7)
    where v is the speed of the transistor, and other parameters
    have their usual meanings. (7) shows that v decreases greatly
    as Vt increases,
    is lower than 388nW. Alternatively, 70% of the samples with
    the low V, transistors consume leakage power higher than
    388nW. These results indicate that DTV is highly effective to
    reduce the total leakage power consumption even under
    significant process and temperature variations. Also, two
    active power distribution curves intersect at 15uW. The active
    power consumption of 91% of the dual V, samples is lower
    than 15uW and 90% of the low V, samples consume active
    power higher than 15uW. This is because the active power
    consists of the switching power and the leakage power and
    DTV can be effective to suppress leakage power, thereby
    reducing the total active power.
    As also can be seen from Fig. 2, the delay of all 4-input OR
    sample gates (100%) with DTV is lower than 490pS, while
    that of all low V, samples (100%) is higher than 490pS.
    Obviously, under the effect of the temperature and process
    variations, the inferior speed characteristics of the high V,
    transistors in circuit with DTV still induce the speed penalty
    as expressed in equation (7) [9]
    ( J
    1.3
    V 0.3 1-~
    dd V
    dd vex:--------
    MUX16), are employed as the benchmark circuits. They are
    simulated based on 45nm BSIM4 models [15] by the HSPICE
    tool. Each domino gate drives a capacitive load of 8fF. The
    parameters of devices are listed in table I. All gates are turned
    to operate at 1GHZ clock frequency and W/L in PDN is set to
    5-20 [16]. When simulating the leakage power, all of the
    domino OR gates are set in CHIH (clock=l, In_1= In_2= ...
    In_n =1) state, which can ensure every gates in the lowest
    leakage state [6].
    To evaluate the impact of process and temperature
    variations on the effectiveness of DTV, process and
    temperature variations aware power and speed characteristics
    of domino circuits with DTV is evaluated using multipleparameter
    Monte Carlo analysis. In our simulation, three most
    important process parameters to influence the performance of
    the MOSFET are considered: gate length (Lgate) , channel
    doping concentration (Nch) , and gate oxide thickness (tox) . And
    these parameters are all assumed to have normal Gaussian
    statistical distributions with a three sigma (30) variation of
    10%. In addition, temperature is assumed to have uniform
    distribution and varies the normal value (75°C) by ± 50°C.
    1000 Monte Carlo simulations are run to evaluate the power
    and delay distribution of different domino gates.
    Taking 4-input dual V, OR gate as an example, its leakage
    power, active power and delay characteristics at the presence
    of process and temperature variations are shown in Fig. 2. As
    can be seen from it, the leakage power distribution curves of
    the low V, and dual V, domino OR gates cross at 388nW.
    Leakage power consumption of88% of the samples with DTV
    250
    490pS +Dual Vt Delay
    200 LowVtDelay
    20
    en
    -(la) 00 150
    § en 80
    4-.
    0 100
    ;.... 60
    (l)
    ..D
    E
    ;:$ 50 Z
    Leakage Power (nW)
    Fig. 2 Leakage power, active power and delay distribution of 4-input dual V, domino OR gate
    100
    100
    100
    100
    100
    100
    100
    100
    D<Cross/%
    279 13 480 93 77 100 72 70
    388 15 490 88 91 100 70 90
    611 16 530 86 74 100 70 66
    938 19 540 65 66 100 60 79
    705 19 591 82 87 100 61 64
    2021 20 676 69 61 100 52 90
    388 22 460 88 86 100 70 95
    1650 23 632 63 96 100 61 94
    OR2
    OR4
    OR8
    OR16
    AND2
    AND8
    MUX2
    MUX16
    TABLE II
    DISTRIBUTION OF LEAKAGE POWER, ACTIVE POWER AND DELAV OF THE DOMINO GATES (L: LEAKAGE POWER; A: ACTIVE POWER; D: DELAv)
    Gate Cross Dual Vt Low Vt
    L/nW A/uW DipS L<Cross/% A<Cross/% D>Cross/% L>Cross/% A>Cross/%
    1238
    D(pS)
    TABLE III
    THE AVERAGE AND STANDARD DEVIATIONS (SD) OF THE DOMINO GATES (L: LEAKAGE POWER; A: ACTIVE POWER; D: DELAY)
    Gate Dual Vt Low Vt
    (Average/SD) L(nW) A(uW) D(pS) L(nW) A(uW)
    OR2 195/72.0=2.70 13/0.94=13.83 589/34.8=16.91 590/371=1.58 15.4/1.1=14.00
    OR4 286/115=2.49 13.1/0.9=14.89 598/35.4=16.91 682/394=1.73 16.2/1.1=15.12
    OR8 467/200=2.33 15.0/1.0=15.03 656/45.6=15.07 865/450=1.92 17.2/1.1=15.54
    OR16 913/411=2.22 18.7/1.2=16.22 489/32.7=17.97 1338/625=2.14 21.0/1.2=18.23
    AND2 583/253=2.30 18.1/1.00=18.1 683/29.5=23.19 984/491=2.01 20.2/1.84=10.99
    AND8 1939/868=2.23 19.6/2.00=9.79 787/25.8=30.47 2398/1089=2.20 23.5/2.62=8.98
    MUX2 285/114=2.49 21.9/0.89=24.5 532/28.8=18.45 685/398=1.72 24.4/1.01=23.10
    MUX16 1711/754=2.27 21.5/0.87=24.61 544/36.8=14.78 2.64/934=2.21 24.8/1.11=22.28
    425/15.2=28.00
    417/15.1=27.64
    446/12.2=36.68
    315/12.2=25.85
    450/11.0=40.90
    584/15.6=37.27
    409/16.10=25.37
    362/12.75=28.43
    Table II lists the leakage power, active power and delay
    characteristics of OR2, OR4, OR8, OR16, AND2, AND8,
    MUX2, and MUX16 domino gates. As indicated in it, with the
    increasing number of the inputs, the values of the point of
    intersection of the leakage power, active power and delay all
    increase gradually. As to leakage power and active power,
    over 50% samples of all of the dual V, domino gates are
    smaller than the cross, and alternatively over 50% samples of
    all of the low V, domino gates are lager than the cross.
    Therefore, under the effect of the temperature and process
    variations, DTV is still quite effective to reduce the total
    leakage and active power consumption for all style of domino
    gates with speed loss.
    The average and standard deviations (SD) of dual V, and
    low V, domino gates are listed in Table III. The Average/SD
    values of the leakage power of all the dual V, gates are larger
    than that of the low V, gates, which shows that DTV can
    sustain the availability of suppressing leakage power with the
    process and temperature variation.
    Also can be seen form Table III, the Average/SD value of
    delay of all domino gates with DTV are less than that of the
    low V, gates and therefore DTV could weaken the immunity
    of the domino gates to process and temperature variation
    regarding the delay characteristics.
    In addition, as to domino OR gates with DTV, the
    Average/SD value of active power are less than that ofthe low
    Vt OR gates, but the Average/SD value of active power of
    AND and MUX gates with DTV are larger than that of the
    low V, gates. This is because in the PDN of AND and MUX
    gates, the transistors are cascaded and thereby produce stack
    effect to lower the leakage power, which improve the
    robustness of domino gates against effect of process and
    v. CONCLUSION
    Effectiveness of the dual threshold voltage technique (DTV)
    in domino logic design is analyzed based on multipleparameter
    Monte Carlo simulation. Simulation results indicate
    that DTV is highly effective to reduce the total leakage and
    active power consumption for domino gates with speed loss
    under significant temperature and process variations. And
    DTV can sustain the availability of suppressing leakage power
    in domino gates with different structures. However, DTV
    could weaken the immunity of the domino gates to process
    and temperature variation regarding the delay characteristics.
    As to the active power, the domino AND and MUX gates with
    DTV have more robustness against process and temperature
    variation than domino OR gates.
    REFERENCES
    [1] Ratnayake R., Kavcic A., and Gu-Yeon Wei, "A High-Throughput
    Maximum a Posteriori Probability Detector," IEEE Journal of SolidState
    Circuits, vol. 43, pp. 1846-1858, Aug. 2008.
    [2] Sapumal B. Wijeratne, Nanda Siddaiah, et al, "A 9-GHz 65-nm Intel®
    Pentium 4 Processor Integer Execution Unit," IEEE Journal of SolidState
    Circuits, vol. 42, pp. 26-37, Jan. 2007.
    [3] S. Rusu, G. Singer, "The First IA-64 Microprocessor," IEEE Journal of
    Solid-State Circuits, vol. 35, pp. 1539-1544, Nov. 2000.
    [4] Liu, Z., Kursun, V. Leakage power characteristics of dynamic circuits in
    nanometer CMOS technologies. IEEE Transactions on Circuits and
    Systems II, vol. 53, pp. 692-696, Aug. 2006.
    [5] Jinhui Wang, Na Gong, Shoubo Feng, et al. "A Novel P-type Domino
    AND Gate Design in Sub-65nm CMOS Technologies," Chinese Journal
    of Semiconductors, vol. 28, pp. 1818-1822, Dov. 2007.
    [6] 1. T. Kao, A. P. Chandrakasan, "Dual threshold voltage techniques for
    low-power digital circuits," IEEE Journal of Solid-State Circuits, vol. 35,
    pp. 1009-1018, Jul. 2000.
    [7] Yuh-Fang Tsai, N. Vijaykrishnan, Yuan Xie, and Mary Jane Irwin.,
    "Influence of Leakage Reduction Techniques on Delay/Leakage
    uncertainty" 18th International Conference on VLSI Design, 2005: 374379.
    [8] Jim Tschanz, Keith Bowman and Vivek De, "Variation-Tolerant
    Circuits: Circuit Solutions and Techniques", Proceedings of the 42nd
    annual conference on Design automation, 2005: 762-763.
    [9] Na Gong, Baozeng Guo, Jianzhong Lou, et al, "Analysis and
    Optimization of Leakage Current Characteristics in Sub-65nm Dual Vt
    Footed Domino Circuits," Microelectronics Journal, vol. 39, pp. 11491155,
    Sep. 2008.
    [10] Kursun, V., Friedman, E.G., "Sleep Switch Dual Threshold Voltage
    Domino Logic with Reduced Standby Leakage Current," IEEE
    Transaction on VLSI Systems, vol. 12, pp. 485-496, May 2004.
    [11] Taur, Y., Ning, T.H.: Fundamentals of modem VLSI devices.
    Cambridge: Cambridge University, 1998
    [12] D. Boning, S. Nassif. Design of high performance microprocessor
    circuits. Piscataway, NJ: IEEE Press, 2000
    [13] Kumar, S.V. Kim, C.H. Sapatnekar, S.S., "Body Bias Voltage
    Computations for Process and Temperature Compensation.," IEEE
    Transaction on VLSI Systems, vol. 16, pp. 249,249-262, Mar. 2008.
    [14] X. Xi et aI., BSIM4.3.0 MOSFET Model - User Manual, Department of
    Electrical and Computer Engineering, University of California,
    Berkeley, 2003.
    [15] Predictive Technology Model (PTM), http.z/www.eas.asu.edu/cptm
    [16] Jinhui Wang, Na Gong, Ligang Hou, et al, "Charge Self-compensation
    Technology Research for Low power and high performance Domino
    circuits," Chinese Journal of Semiconductors, vol. 29, pp. 1412-1416,
    Jul. 2008.
    1239
