  3. ILM directories switched during report_timing - SOC81 U...
  • Subscribers 94
  • Views 1106
ILM directories switched during report_timing - SOC81 USR3
Vishnu Chada
Vishnu Chada over 16 years ago
I'm using the following script to time the toplevel timing.
restoreDesign opt.enc.dat  topmodule
specifyIlm -cell A -dir ./ilm_dir/A_ilm
specifyIlm -cell B  -dir ./ilm_dir/B_ilm
flattenIlm
report_timing
When i look at the log file , i see that the tool creates and intermittent sdc file topmodule.ilm.sdc which has the fillowing
source sdc/topmodule.pt
set SOCE_SDC_PUSH_DOWN_IGNORED 1
current_instance
current_instance topmodule/A
source ./ilm_dir/B_ilm/B.core.sdc
current_instance
current_instance  topmodule/B
source ./ilm_dir/A_ilm/A.core.sdc
set SOCE_SDC_PUSH_DOWN_IGNORED 0
 I can see the switch in the sdc files when flattening the ilm.
I believe this is a issue and i'm not looking at the right timing, looking for some suggestion or comments  on the above behavior.
Appreciate your time.
Vishnu
  • Kari
    Kari over 16 years ago
     Please file a service request at support.cadence.com
