  3. IMPORTING GDS
  • Subscribers 94
  • Views 15643
IMPORTING GDS
archive over 18 years ago
Hi All, Can any one calify me the following concept: If i had a GDS file with me without having design data(i.e. design.enc format),is ti possible to import the design in encounter? If so ,explain the process with an example. KVB
Originally posted in cdnusers.org by viswanadhbabu
    Hi KVB,
    This is not possible. You need to start with a netlist. You might be able to do some sort of workaround using OA, but I don't know your exact situation (and I'm not an OA expert either).
    - Kari
    Originally posted in cdnusers.org by Kari
  • Tezztech
    Tezztech over 14 years ago
    Hey Kari,
    Say you have a gds file and you have a netlist generated from a program such as micromagic max? I want to import those files into encounter do you have any suggestions?
    Anita
  • Kari
    Kari over 13 years ago
    Hi Anita,
    Again, I'm no expert with the OA stuff, so there may be something you can do there if you can get the design into virtuoso. But otherwise, you need LEF files and .lib files at a minimum along with the netlist.
    - Kari
