  3. problem with ecoAddRepeater
  • Subscribers 93
  • Views 15903
archive over 18 years ago
hi all,
i have a problem with ecoAddRepeater command.
when i am trieng to add a buffer to SE pin of a spare Gate cell by ecoAddRepeater command it is giving " desired buffering is infeasible" . But when i add to SI pin of same cell it is working.
and also working for the other SE pins of flops (not spare flops) which are driven by same net
thanks
madhavi.
Originally posted in cdnusers.org by madhavi.komma
    By any chance is the net connected to SE pin a create_clock or create_generated clock? Just a guess. In other tools in the past add repeater has not worked on clock paths.
    Sanjay
    Originally posted in cdnusers.org by ssunder@sioptical.com
    hi
    did you try addbuffer --term -cell buffer . -prakash
    Originally posted in cdnusers.org by pjayasekharan
