  3. How to constraint the Input/output Port in SignalStorm?
  • Subscribers 93
  • Views 3026
archive over 18 years ago
I use the SignalStorm to calculate delay, the scripts use db_delay db_screen like command.
 I know there are two ommand  related to the IO enviroment, set_driving_cell and set_load
and  there are sytax in the docs, but I could not set it right in my scripts.
set_load
set_load
{-pin | -net | -inst}
name
value
set_driving_cell
set_driving_cell
-pin [cell]:pin
-cell cell_name
-from input_pin
-to output_pin
How should  I define all the Inputs ports or the outputs ports ?
[all_inputs] and [all_outputs] do NOT work.
Anyone interested this problem ?
Originally posted in cdnusers.org by aidans
    Hi aidans,
    From the syntax you show here, it looks like you're using standalone SignalStorm (as opposed to running within SoC-Encounter or Encounter Timing System). Within SoC-Encounter, it seems like [all_outputs]/[all_inputs] would work as you expect:
    encounter 9> help set_driving_cell
    Usage: set_driving_cell [-library ] [-lib_cell
    ] [-pin ]
    [-from_pin ]
    [-rise | -fall] [-min | -max]
    [-input_transition_rise ]
    [-input_transition_fall ]
    It sounds like the behavior is different in standalone SignalStorm. If you're unable/don't want to run SignalStorm from within SoC-Encounter or ETS, maybe you could target the ports with a "*"? Have you tried that? The commands might be smart enough to know that set_load should only be applied to all outputs and set_driving_cell to all inputs.
    Please post back and let us know whether this is still an issue for you.
    Bob
    Originally posted in cdnusers.org by BobD
    Thanks Bob
    Yes, It is standalone version of Signalstorm
    with your sugesstion, I use * as the target port, porblem is solved.
    The driver cell and load have effect as expected.
    The tools are really very smart.
    Thank YOU !
