  3. encounter - .conf file
  • Subscribers 94
  • Views 1143
Yemelya
Yemelya over 16 years ago
Where can I find the description and syntax of “.conf” file and particularly of power supply and power pins definition? Encounter Text Command Reference doen't have any.
-Boris
  • wally1
    wally1 over 16 years ago
    Hi Boris,
    Chapter 44 of the Text Command Reference includes this information. A link is below:
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/fetxtcmdref/fetxtcmdref9.1.2/configT.html
    Typically, you define the global power nets in the .conf file then use globalNetConnect or CPF to define the connections. Connections specified with globalNetConnect are then saved to the floorplan file.
    Brian
