  3. cascade buffers on DontTouch nets during CTS
  • Subscribers 93
  • Views 15554
Rajesh Vembu
Rajesh Vembu over 16 years ago
CTS engine doesn't seem to honor DontTouch nets, as some CASCADE buffers are added on the DontTouch nets.
Can someone share some thoughts on
1. why CTS engine doesn't honor DontTouch nets?
2. is there a way to instruct the tool to avoid insertion of CASCADE buffers on DontTouch nets?
Regards
Rajesh
  • Kari
    Kari over 16 years ago
     Do you have the following near the top of your .ctstch file?
    DontTouchNet
    + net1
    + net2
    etc...
  • Rajesh Vembu
     Kari,
    I do have "DontTouchNet" syntax. Infact, i even had "DontTouchFromToPin" syntax, still the cascade buffers are inserted. I found this behavior in EDI 9.1.
    Please let me know how we can avoid these cascade buffer insertion on DontTouchNets
    Regards
    Rajesh
  • Kari
     Double-check the syntax of your clock spec file, make sure the nets listed exist, and check the log file for any problems that may have occurred during reading of the clock spec file or with the use of the DontTouchNet or DontTouchFromToPin commands. If everything checks out ok, then please file a service request at support.cadence.com, because it sounds like a bug.
    - Kari
