  3. selecting a net next to a given net
  • Subscribers 94
  • Views 16781
KVBABU
KVBABU over 16 years ago
how to select a net next to a net with the db command.
Iam using the below command to get but  iam not getting some body help me
 dbWireNextInNet
  • Vishnu Chada
    Vishnu Chada over 16 years ago
    can you post the script or the command sequence you are using to get the wire pointer ? It would be good to know the intent behind using the the command , there could be an easier way..
  • sambasiva
    sambasiva over 16 years ago
     set fp1 [open "nets_list" "r"]
    set fp2 [open "nets_next_list" "w"]
    foreach net [gets $fp1] {
    set netPtr [dbGetNetByName $net]
    dbForEachNetWire $netPtr segmentPtr {
    set c [dbObjName [dbWireNet $segmentPtr]]
    puts $c
    dbWireNextInNet $segmentPtr
  • sambasiva
     Hi Vishnu
    To explain the problem clearly ......
    I want to select a net (physically) next to a given net in the design after routing .With the above scipt iam not able to get it.
    help me
  • BobD
    BobD over 16 years ago
    I think the best way to do this is to expand the box of a selected wire segment and use "editSelect" to find wires within that box on the same layer:
    set selected [dbGet selected]
    if {$selected == "0x0"} {
      Puts "Nothing selected"
      return
    } elseif {[llength $selected] != 1} {
      Puts "More than 1 wire selected - select a single wire segment and try again"
      return
    set selectedWire [dbGet selected]
    set pts [dbGet $selectedWire.pts]
    set net [dbWireNet $selectedWire]
    Puts "INFO: Original wire segment is $selectedWire of net [dbGet $net.name]"
    set layer [dbGet $selectedWire.layer]
    set layerName [dbGet $layer.name]
    set direction [dbGet $layer.direction]
    if {$direction == "Horizontal"} {
      set pitch [dbGet $layer.pitchY]
      set llx [lindex [lindex [lindex $pts 0] 0] 0]
      set lly [expr [lindex [lindex [lindex $pts 0] 0] 1] - $pitch]
      set urx [lindex [lindex [lindex $pts 0] 1] 0]
      set ury [expr [lindex [lindex [lindex $pts 0] 1] 1] + $pitch]
    } else {
      set pitch [dbGet $layer.pitchX]
      set llx [expr [lindex [lindex [lindex $pts 0] 0] 0] - $pitch]
      set lly [lindex [lindex [lindex $pts 0] 0] 1]
      set urx [expr [lindex [lindex [lindex $pts 0] 1] 0] + $pitch]
      set ury [lindex [lindex [lindex $pts 0] 1] 1]
    set rdagSelectIntersectingBox 1
    editSelect -area $llx $lly $urx $ury -layer $layerName
    Puts "Nearby wire segments:"
    foreach wire [dbGet selected] {
      Puts "  Wire segment $wire of net [dbGet [dbWireNet $wire].name]"
    Example result:
    INFO: Original wire segment is 0x2aa95bb668 of net {high_mag[3]}
      Wire segment 0x2aa9643ae0 of net n_6011
      Wire segment 0x2aac53fc30 of net n_2506
      Wire segment 0x2aa96270e8 of net {high_mag[3]}
      Wire segment 0x2aa95bb668 of net {high_mag[3]}
    Hope this helps,
    Bob
  • sambasiva
    Hi Bob
    Thank you so much for your response and script geven below.
    Means there is no use of dbWireNextInNet command.
    sambasiva
  • sambasiva
    Hi Bob
     Iam not able to run the scipt given above.
    Isue is with the  command
    'direction' is not a recognized object/attribute. For help use 'dbGet <object>.?' to get list of all supported objects and attributes
     Correct me
