  3. Output gds in Encounter
  • Subscribers 94
  • Views 14677
bsdevlin
bsdevlin over 16 years ago
I am trying to export a gds from encounter. I cannot get the pin labels to be outputted with the GDS.
In my stream outfile, I have a metal layer M1L which I am using for pins. It is layer 11 in the techfile.
eg:
M1L     ALL   11  0
So I add the following line to my steamout file:
NAME   PIN    11  0
Which is as far as I understand what I should do to get the labels of my pins included in the exported gds.
But when I export the gds I get no text objects:
Stream Out Information Processed for GDS version 3:
Units: 1000 DBU
Object                             Count
Instances                            157
Ports/Pins                            36
    metal layer M2L                    9
    metal layer M3L                   16
    metal layer M4L                    3
    metal layer M5L                    6
    metal layer M6S                    1
    metal layer M7T                    1
Nets                                 387
    metal layer M1L                    7
    metal layer M2L                  210
    metal layer M3L                  142
    metal layer M4L                   20
    metal layer M5L                    6
    metal layer M6S                    2
    Via Instances                    483
Special Nets                           8
    metal layer M1L                    4
    metal layer M2L                    4
    Via Instances                      8
Metal Fills                            0
    Via Instances                      0
Metal FillOPCs                         0
    Via Instances                      0
Text                                   0
Blockages                              0
Custom Text                            0
Custom Box                             0
Is there some setting or otherway to get the pin text exported with the gds?
  • bsdevlin
    I figured out I needed to write:
    NAME   M1L/PIN 11 0
    And now it works.
