  3. dbForEach dbForAll and db*Next* difference
  • Subscribers 94
  • Views 1683
iclabwhoami
iclabwhoami over 16 years ago
Hi ,
Do anyone know what's the difference between  dbForEach* and dbForAll *?  why does it need to use db*Next*
in iteration loop?
  • iclabwhoami
    I also found there are dbIterAllRoutes ,dbIterRoutes ,dbEndIterRoutes,dbEndIterAllRoutes,so I think dbNext* are used in this iteration method, such as the following code :
    set iter [dbIterRoutes $net]
    while {[set route [dbRouteNext $iter]] != "0x0"} {
    if [dbIsRouteWire $route] {
    set wire_info [dbInfoWire $route]
    } elseif [dbIsRouteVia $route] {
    set via_info [dbInfoVia $route]
    } else {
    puts "something’s wrong\n"
    if (want to break out of the iterator loop)
    dbEndIterRoutes $iter
     But I'm wondering why  cadence add this new iteration method,  and what's difference between dbIterRoutes and dbIterAllRoutes? Thanks!
  • BobD
    BobD over 16 years ago
    I seem to these commands being necessary when there wasn't a data-type-specifc dbForEach* iterator command available.  The dbForAll (as opposed to dbForEach) seemed to be necessary when you wanted to iteration through, for example, power pins in addition to signal pins when iterating through pins on a cell.
    However, you should be able to get at this information with the dbGet command that debuted in 7.1.  Are you seeing some cases where you still need to use these old style commands?  If so let us know so we can improve dbGet and/or help with usage of some of these more confusing old style commands.
    Bob
  • iclabwhoami
    Hi Bob,
    Thanks for your reply, I think Encounter have design to have many commands, it have very powerful and flexible command to let use to investigate and operate database, But it's not easy for user to find the exact command to implement user's intent, I think dbGet,dbSet is more easy to let user get some attribute since it's structured and more organized. anyway it will need  time to be expert in encounter
