  3. Placing Via where I want it.....
  • Subscribers 94
  • Views 15036
vincp
vincp over 16 years ago
 Is there a command to place a via  at a particular co-ordinate in Encounter (I am using 8.1)? I am trying to place TSV type via (which I have defined in the lef and tech files) in a particular grid fashion....
  • Kari
    Kari over 16 years ago
    You can use
    setViaEdit -viacell myVia
    to name the via you want to place, then use
    editAddVia x y
    to place the via. Check the Text Command Reference for more details/options of these commands.
    - Kari
  • vincp
     Thank you.... That helped a lot
