  3. Physical Pin Minarea violation
  • Subscribers 93
  • Views 16199
archive over 18 years ago
Dear all
wen i go for the command verifygeomertry after cts and just before routing using nanoroute. I get lots of violations for min area. When i check this in violation browser most of them are physical pin  min area violation. I generated the .io file using the encounter at floorplan stage and i dont have any fixed .io file. So can some one please tell me how could i over come this violations.
Thanks for ur help in advance
Suresh
Originally posted in cdnusers.org by suresh235
    Normally verify geometry/verify connectivity should be done after completing routing.If you are seeing minarea violations at physical pins even after routing,you should increase the size of the physical pins.(provided you haven't fixed the pins).This will get rid of the violations you are facing
    Originally posted in cdnusers.org by abhiroy03
    hi
    Thanks for your reply . but as rule for nanometer, its mentioned in the manual to verify the connectivity and geometry even b4 u start routing so that the violations can be fixed for a smooth routing. and i had done accordingly, but there are many pins with violations infact 95 % of the violations r physical pin viol.
    Any advices
    Suresh
    I think you should always verify geometry before routing. No reason to route if you have a problem with your power plan. I'm a little surprised that you have any min area violations that aren't phisical pins. I just run verifyGeometry with -minArea option so they are ignored before routing.
    Originally posted in cdnusers.org by sreeb
