  3. What is the equivalent of "synopsys translate_[on|off]
  • Subscribers 92
  • Views 7759
Karthik244
Karthik244 over 15 years ago
Synopsys-DC allowes the designers to embed "synopsys translate_off followed by translate_on" in the RTL, to inform DC that the RTL code inside those two statements should not be synthesized.
What is the equivalent procedure in RC?
  • grasshopper
    grasshopper over 15 years ago
     Same thing. RC supports a number of SNPS pragmas or if you are more of a purist you can replace with
     // cadence translate_on/off
    The folllowing attribute allows you to create your own pragma keyword
     attribute name: input_pragma_keyword
              category: hdl (controls HDL file processing)
           object type: root
           access type: read-write
             data type: string
         default value: cadence synopsys get2chip g2c ambit pragma
                  help: Specifies pragma keywords.
    regards,
    gh
