  3. About Encounter Warning 'TA-549'
  • Subscribers 93
  • Views 6382
archive over 18 years ago
hi All:
I get the following message when run timing analysis:
--> WARNING: Pin 'msd_ddr_phy/ddr_sstl/dll_ato_io125/AE' is driven 'ZERO' and
             'X' simultaneously, preserving 'X.' .
--> WARNING: Pin 'msd_ddr_phy/ddr_sstl/dll_dto_0_io121/OJ' is driven 'ZERO' and
Why? Does it relate to constant propagation? where comes the 'X'?
Originally posted in cdnusers.org by eminemshow
    If there a different drivers on a net, and they are not driving the same signal state (0,1,X) on to the
    net, then system has to resolve which state the signal is in in order to propagate forward.
    The Warning you see indicates that there is such a conflict - in the case between a X (unknown) state and 0 (ZERO)
    state. The timer resolves this "conservatively" by keeping the X. All signals have a state value of X in the timer
    unless some explicit state assertion is made (set_case_analysis), and propagated forward.
    Other tools (PT I think) resolve the above scenario to ZERO rather than X. There is a CTE global to provide a similar
    resolution policy:
    set_global timing_resolve_driver_conflicts {conservative | aggressive}
    default: conservative
    (Note: for some reason this global is not in the current doc set. We'll look into getting that added)
    Originally posted in cdnusers.org by ejm
    Many thanks. EJM!
    If there is a X state, what does this stand for? Does X means '0' or '1'? Or X means 'high resistance state'?
