  3. set_timing_derate for RC
  • Subscribers 94
  • Views 15422
Yemelya
Yemelya over 15 years ago
What is the RC equivalent of set_timing_derate?
It should be compatible, but it causes error if used in RC script, and just ignored when loaded by read_sdc.
-Boris
  • mclarke
    mclarke over 15 years ago
    Hi Boris,
    set_timing derate is an sdc command and RC does support most command options see the rc doc rc_ta.pdf for details.
    In rc direct use as with all sdc commands use dc::set_timing_derate
    Cheers,
    Mike
  • Yemelya
    Thanks!
