  3. Compatibility problem between ELC and Verilog-A
  • Subscribers 95
  • Views 14936
Bastien
Bastien over 15 years ago
Hi all,
I want to create .lib files from elc with hspice simulator and a transistor model made with Verilog-A.
FYI, when I used a standard model (not in VerilogA), everything works properly and the .lib are generated.
When I use the model written in VerilogA, I am facing the following problem:
During the db_prepare step: the elc execution stops because when analyzing the model file and the following message appears:
Reading SUBCKT:NMOSFD
Reading SUBCKT:PMOSFD
[WARNING(db_prepare)] spice syntax warning: NMOSFET : no definition of the subckt
 => XM1 D G S 0 NMOSFET
[WARNING(db_prepare)] spice syntax warning: PMOSFET : no definition of the subckt
 => XM1 D G S 0 PMOSFET
SUBCKT FILE: std_cells.sp ( #size = 282 )
Reading SUBCKT:IVX2
Expanding SUBCKT:IVX2
... XM1 [NMOSFD]
... XM0 [PMOSFD]
- subckt : NMOSFET is not defined
- subckt : PMOSFET is not defined
[ERROR(db_prepare)] Cannot read the input SPICE file subckt : NMOSFET is not exist. because it has one or more syntax errors. Correct the SPICE syntax in the file and try again.
Please note that we never have any error when simulations this verilogA model with Hspice directly without ELC.
Actually when ELC tries to read the model file without opening hspice, I think ELC is expecting a subckt and not a link with a VerilogA file.
Does anybody know how to do to make ELC understand this?
Or how to prevent prevent elc from checking the model before simulating with hspice during the db_prepare?
Bastien
  • rangha
    rangha over 15 years ago
    I am facing the same problem. I would like to use verilog A model to create .lib files.
    Did you find a solution for this?
    Regards
    Rangha
