  3. power planning >> addRing
  • Subscribers 93
  • Views 854
archive over 18 years ago
E created a rectilinear contour for the core with the placement blockage using the partition cut. so when i addRing around the contour of the block, it says:
selected placement blockage (x1, y1, x2, y2) will be considered by addRing command as placement objects.
another thing is that the Encounter won't let me addRing using the type: core ring(s) contouring. it says the check design boundary or specify valid offsets.
please help.
thanks,
chhay
Originally posted in cdnusers.org by kongtep2
