  3. Boundary scan insertion and input pad with enable
  • Subscribers 94
  • Views 14920
mnewsam
mnewsam over 15 years ago
 I am inserting boundary scan into a design and I have two LVDS pads which have a common enable signal that comes from another input pad.
One of the pads is an output and the boundary scan insertion correctly has a bcell element controlling the enable signal.
The input pad however is not controlled by the bcell element but the signal from the other input pad.
Is there a way to make the tool connect the bcell element to the input pad?
I have a IOSpecList with a section shown at the end of this post showing the input and output definition and the common controlling signal g1/z.
The only solution I can think of at the moment is to use edit_netlist.
   Mark
Spw_data_in_p   bdy_in=i_spw_din_in/cin \
                cell=pl33rxz \
                differential=Spw_data_in_n \
                sys_use=input \
                sys_enable=g1/z \
                bcell_required=true
Spw_data_in_n   sys_use=none \
                bcell_required=false
g1/z    sys_use=enable \
        bcell_required=true
Spw_data_out_p   differential=Spw_data_out_n \
                 cell=pl33txz \
                 sys_enable=g1/z \
                 sys_use=output3 \
                 bcell_required=true
Spw_data_out_n   sys_use=none \
