  3. set_clock_groups
  • Subscribers 93
  • Views 16038
set_clock_groups
archive over 18 years ago
seems that this sdc command (set_clock_groups) is not supported by default even in FE7.1 since I received message: WARN: (TCLCMD-1044) Command set_clock_groups is not supported.
However, sourcelink has some note, which said that if you "setenv nativeCTECstrReader 1", CTE may recognize the command.
Has any expert here tried this sdc command? Does it work well if we use "setenv nativeCTECstrReader 1"?  Why we need to "setenv nativeCTECstrReader 1" to use the comamnd? any negative impact to have nativeCTECstrReader=1?
Tongju
Originally posted in cdnusers.org by Tongju
    Hi Tongju,
    I don't think this command will be supported until 8.1.
    - Kari
    Originally posted in cdnusers.org by Kari
