  3. ERROR: CPF file incomplete
  • Subscribers 94
  • Views 15760
Yemelya
Yemelya over 15 years ago
I started creating a CPF according to cpf_ref.pdf document from Cadence. But obviously I am missing something. But what?
The CPF and the error message attached below.
May be somebody has and could share a good (accomplished) example of CPF file for encounter to be a base to start with.
Thank you very much!
-Boris
__________________________
set_design AAA
create_power_domain  -name PD_VDD    -instances {BBB/CCC BBB/DDD}
create_power_domain  -name PD_VDD_SW -default
define_library_set -name PD_VDD_SW_set -libraries {../LLL_1.2v_25c.lib}
define_library_set -name PD_VDD_set    -libraries {../LLL_1.2v_25c.lib}
create_nominal_condition -name high -voltage 1.32
create_power_mode -name PM1 -default -domain_conditions { PD_VDD_SW@high PD_VDD@high }
update_power_mode -name PM1 -sdc_files ./timing.sdc
create_bias_net -net vdd_sw -driver analog_top/VSS_SW
create_bias_net -net vdd    -driver analog_top/VSS
create_global_connection -net vdd_sw -domain PD_VDD_SW -pins analog_top/VDD_SW
create_global_connection -net vdd    -domain PD_VDD    -pins analog_top/VDD
end_design
INFO: processed 11 CPF commands in 60 lines from file CPF.tcl, with 0 errors
Checking CPF file ...
**ERROR: (ENCCPF-243):  can't bind power domain PD_VDD to a library_set
**ERROR: (ENCCPF-243):  can't bind power domain PD_VDD_SW to a library_set
**ERROR: (ENCCPF-237):  library set not specified for nominal condition high in default power_mode PM1
**ERROR: (ENCCPF-249):  CPF file incomplete
  • patrice06
    patrice06 over 15 years ago
     Hi Boris,
    I have little experience with CPF but as I run in the same error message, I have learned that the message is due to a missing statement in the CPF file : update_nominal_condition. This statement makes the binding between library and power domain. With your name definition, you should add something like:
    update_nominal_condition -name high -library_set PD_VDD_set
     Best Regards
    Patrice
  • Yemelya
    Thank you Patrice!
    I'll try it.
    Best regards,
    -Boris
