  3. hoho, Bob, 1 question again for CTS
  • Replies 7
  • Subscribers 94
  • Views 16842
archive over 18 years ago
1. How can I get all the clock nets in SOC-E. I am using the command 'dbIsNetClock', but it doesn't work. Then I try to specify clock tech file, then change all the clock nets to DEF USE CLOCK, then output DEF, reload the DEF, but 'dbIsNetClock' does not work either. I can write a DB tcl to trace the clock tree, but it is time consuming. How can I do this using FE inherent commands. My SOC-E version is 52USR3.
Thanks in advance!
Originally posted in cdnusers.org by eminemshow
    'dbIsNetClock', uses the timing information to tell is a net is clock or not.
    You should load the SDC and update the timing before using this command.
    Originally posted in cdnusers.org by sudhir.jain
    As you read a DEF, the informations are saved on an other property. If you read you SDC and update your timing you may have problem with multimode. So teh better is to make two tests:
    Here is my script:
    proc userCreateClockList { clockFile {option w} } {
    set f [open $clockFile $option]
    dbForEachCellNet [dbgTopCell] n {
    set netname [dbNetName $n]
    if {[dbIsNetClock $n] || [dbIsNetDefInClock $n]} {
    puts $f "$netname"
    close $f
    And so you can use:
    userCreateClockList $STM_clockNetsReport "w"
    Regards ... Luc ...
    Originally posted in cdnusers.org by Black Lutin
    Thank you all! This is really the solution I need.
    Lutin:
    I really dont not know why comands like 'dbIsNetClock' and 'dbIsNetDefInClock' doesn't work.
    I have to 1st specify clock tree, then saveClockNet, then remark the clock net as 'dbSetIsNetclock'.
    BRs
    To access to dbIsNetDefInClock, you need to have run the clcokTreeSynthesis.
    To access to dbIsNetClock, you need to have read SDC timing constrain file, and to have run a timing command (to propagate the clock information). So you need at least "report_timing".
    Try and let me know ....
    Regards .....
  • kiranbk
    kiranbk over 15 years ago
    HI ,
    I am looking to find out if all the flops are getting clocks in design . i wish to do this early at the floorplan stage itself  just as a design check . Is there a way to do this ?  i tried to use dbIsNEtDefInClock in a snmall script but i think it only works on a cts database.
    Kindly point me to any command if available to check clock attribute on net before cts.
    Kiran
  • BobD
    BobD over 15 years ago
    Have a look at this solution, "How to list flops not getting covered by CTS":
    http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNu
    mber=11720306;searchHash=00e3628bafd2e513d4427dce395562ec
