  3. ecoAddRepeater - a long CPU time
  • Subscribers 94
  • Views 3448
Yemelya
Yemelya over 15 years ago
My aged script with “addBuffer” command doesn’t work anymore since the command is obsolete.
Unfortunately, the option to use ecoAddRepeater takes a very long cpu time.
Is there a quicker alternative to add off load buffer?
-Boris
  • Kari
    Kari over 15 years ago
     Hi Boris,
     See if the tips in this blog help you:
    http://www.cadence.com/Community/blogs/di/archive/2010/10/19/five-minute-tutorial-ecoaddrepeater.aspx?postID=1181913
    - Kari
  • wally1
    wally1 over 15 years ago
    Hi Boris,
    Is the runtime due to extraction and delay calculation being run after the buffer is inserted? If so, you can disable this by setting:
        setEcoMode -updateTiming false
    Brian
  • Yemelya
    Great!
    It helped. Thanks very much!
    Best regards,
    -Boris
