  3. problems in using ELC(encounter library characterize)
  • Subscribers 96
  • Views 2642
wangweike
wangweike over 15 years ago
hi,thanks for you attention!
I use ELC in my work ,when i type the "db_prepare -force" there goes the warning:
elc>  db_prepare -force
==== Simplify Mode ====
MODEL FILE: amic5n.scs ( #size = 4486 )
Reading MODEL: AMI06N
Reading MODEL: AMI06P
SUBCKT FILE: amic5n.scs ( #size = 4486 )
SUBCKT FILE: dut_sub.scs ( #size = 287 )
Reading SUBCKT:INV
Expanding SUBCKT:INV
Writing : foo.ipdb/INV.design
Writing : foo.ipdb/INV.design/body/path
Writing : foo.ipdb/INV.design/body/instance
Writing : foo.ipdb/INV.design/body/net
Writing : foo.ipdb/INV.design/boundary/port
Reading : foo.ipdb/INV.design
      DESIGN : INV
D0000: : POWER
=> 1 vectors generated
Writing : foo.ipdb/INV.design/simulate/spec
Writing : foo.ipdb/INV.design/simulate/subckt
[WARNING(db_prepare)]alone net : A is found. => [reset to ground]
[WARNING(db_prepare)]Please check whether supply nodes are marked global in the netlist, if not specify them with .global statements
[WARNING(db_prepare)]alone net : Y is found. => [reset to ground]
[WARNING(db_prepare)]alone net : VDD is found. => [reset to ground]
[WARNING(db_prepare)]alone net : GND is found. => [reset to ground]
Writing : foo.ipdb/INV.design/body/type
  stimulus generation  summary
Name            #MOS    #DVEC   #RVEC
INV             0       1       0
                        1       0
 Reading setup file : setup.ss
 -          INV (CELL) -      typical - 2011-02-25 15:11:06 (2011-02-25 07:11:06 GMT)
then i type "db_date" ,it can not recognize the NOT gate
elc>  db_gate
      DESIGN : INV
DESIGN ( INV );
//       PORT DEFINITION
        SUPPLY0 GND ( GND );
        SUPPLY1 VDD ( VDD );
        FEEDTHRU A ( A );
        FEEDTHRU Y ( Y );
//       INSTANCES
END_OF_DESIGN;
- feed-through ( A ) is found
- feed-through ( Y ) is found
can you help me to deal with it ?thanks very much
  • wangweike
    my elccfg file is :
    SETUP = "setup.ss"
    PROCESS = "typical"
    SUBCKT = "dut.scs"
    MODEL = "wwk.scs"
    setup.ss file is :
    // Encounter Library Characterizer setup file
    // Define voltage and temp for process corners
    Process typical{
     voltage = 5.0;
     temp = 25;
     Corner = "TT";
     Vtn = 0.67;
     Vtp = 0.92;
    Process best{
     voltage = 5.5;
     temp = 0;
     Corner = "FF";
     Vtn = 0.63;
     Vtp = 0.89;
    Process worst{
     voltage = 4.5;
     temp = 125;
     Corner = "SS";
     Vtn = 0.71;
     Vtp = 0.92;
    // define measurement percentages for std_cell measurements
    Signal std_cell {
     unit = REL;
     Vh=1.0 1.0;
     Vl=0.0 0.0;
     Vth=0.5 0.5;
     Vsh=0.8 0.8;
    my dut.scs is
    subckt inv A Y vdd  gnd
        \+1 (Y A vdd vdd) ami06P w=6e-06 l=6e-07 as=9e-12 ad=9e-12 ps=9e-06 \
            pd=9e-06 m=1 region=sat
        \+0 (Y A gnd gnd) ami06N w=3e-06 l=6e-07 as=4.5e-12 ad=4.5e-12 ps=6e-06 \
            pd=6e-06 m=1 region=sat
    ends inv
     my wwk.scs is :
    .MODEL ami06N NMOS (                                LEVEL = 11
    +VERSION = 3.1            TNOM    = 27             TOX     = 1.41E-8
    +XJ      = 1.5E-7         NCH     = 1.7E17         VTH0    = 0.7086
    +K1      = 0.8354582      K2      = -0.088431      K3      = 41.4403818
    +K3B     = -14            W0      = 6.480766E-7    NLX     = 1E-10
    +DVT0W   = 0              DVT1W   = 5.3E6          DVT2W   = -0.032
    +DVT0    = 3.6139113      DVT1    = 0.3795745      DVT2    = -0.1399976
    +U0      = 533.6953445    UA      = 7.558023E-10   UB      = 1.181167E-18
    +UC      = 2.582756E-11   VSAT    = 1.300981E5     A0      = 0.5292985
    +AGS     = 0.1463715      B0      = 1.283336E-6    B1      = 1.408099E-6
    +KETA    = -0.0173166     A1      = 0              A2      = 1
    +RDSW    = 2.268366E3     PRWG    = -1E-3          PRWB    = 6.320549E-5
    +WR      = 1              WINT    = 2.043512E-7    LINT    = 3.034496E-8
    +XL      = 0              XW      = 0              DWG     = -1.446149E-8
    +DWB     = 2.077539E-8    VOFF    = -0.1137226     NFACTOR = 1.2880596
    +CIT     = 0              CDSC    = 1.506004E-4    CDSCD   = 0
    +CDSCB   = 0              ETA0    = 3.815372E-4    ETAB    = -1.029178E-3
    +DSUB    = 2.173055E-4    PCLM    = 0.6171774      PDIBLC1 = 0.185986
    +PDIBLC2 = 3.473187E-3    PDIBLCB = -1E-3          DROUT   = 0.4037723
    +PSCBE1  = 5.998012E9     PSCBE2  = 3.788068E-8    PVAG    = 0.012927
    +DELTA   = 0.01           MOBMOD  = 1              PRT     = 0
    +UTE     = -1.5           KT1     = -0.11          KT1L    = 0
    +KT2     = 0.022          UA1     = 4.31E-9        UB1     = -7.61E-18
    +UC1     = -5.6E-11       AT      = 3.3E4          WL      = 0
    +WLN     = 1              WW      = 0              WWN     = 1
    +WWL     = 0              LL      = 0              LLN     = 1
    +LW      = 0              LWN     = 1              LWL     = 0
    +CAPMOD  = 2              XPART   = 0.4            CGDO    = 1.99E-10
    +CGSO    = 1.99E-10       CGBO    = 0              CJ      = 4.233802E-4
    +PB      = 0.9899238      MJ      = 0.4495859      CJSW    = 3.825632E-10
    +PBSW    = 0.1082556      MJSW    = 0.1083618      PVTH0   = 0.0212852
    +PRDSW   = -16.1546703    PK2     = 0.0253069      WKETA   = 0.0188633
    +LKETA   = 0.0204965       )
    * N8BN SPICE BSIM3 VERSION 3.1 (HSPICE Level 49) PARAMETERS
    * DATE: Jan 25/99
    * LOT: n8bn                  WAF: 03
    * Temperature_parameters=Default
    .MODEL ami06P PMOS (                               LEVEL = 11
    +XJ      = 1.5E-7         NCH     = 1.7E17         VTH0    = -0.9179952
    +K1      = 0.5575604      K2      = 0.010265       K3      = 14.0655075
    +K3B     = -2.3032921     W0      = 1.147829E-6    NLX     = 1.114768E-10
    +DVT0    = 2.2896412      DVT1    = 0.5213085      DVT2    = -0.1337987
    +U0      = 202.4540953    UA      = 2.290194E-9    UB      = 9.779742E-19
    +UC      = -3.69771E-11   VSAT    = 1.307891E5     A0      = 0.8356881
    Can you help me ?
    Thank you for you attention
  • Thodoros
    Thodoros over 14 years ago
    Did you manage to solve this problem?
    I have the same case ()
    DESIGN INV should give
    INPUT A ( A );
    However it gives
     FEEDTHRU A ( A );
    As a result the gate is not recognized by the db_gate
    Thanks for your concern
  • Thodoros
     OK
    I think that the problem is the model library.
    I worked on a subset of the ami lib (trying a tutorial on elc) and I had problems.
    However when I did the same tutorial with mine umc90 lib everything rolled smouthly and as should.
    I even managed to have verilog and alf formats of the design
    elc>  db_gate
          DESIGN : INV
    DESIGN ( INV );
    //       PORT DEFINITION
            INPUT A ( A );
            OUTPUT Y ( Y );
    //       INSTANCES
            NOT ( Y, A );
    END_OF_DESIGN;
    elc>  db_close
    I really hope that this helped.
  • hailanw
    hailanw over 11 years ago
    Hi, I encountered the exact same problem, but got to fixed it after some struggling. I figure it is better to have it documented here.
    Actually it is the model file, check if your model file is in the spice format. If so, convert it to the spectre format. In my case, ELC was running without problem after I convert the model file using
    spp -convert <model.spice> model.spectre
    Help it can help others someday.
