  3. Encounter Default Via Definition
  • Subscribers 94
  • Views 14812
eklikeroomys
eklikeroomys over 15 years ago
Halo, I am using Encounter for the Verify step in Abstract Generator, which I am using for creating abstract cell views for a standard cell library. When I run the verify step, I keep getting an error from Encounter saying: ERROR (NRDB-158) There is no default via from LAYER MET1 to LAYER MET2 in RULE LEF_DEFAULT. How can I define these default vias for Encounter? Should I do it in the tech file? Should I also include abstract cell views of the defalut vias? Please help
  • Kari
    Kari over 15 years ago
     The default vias should be part of the tech LEF. Make sure you have a tech LEF and are reading it in.
