  3. long wire transition time issues
  • Replies 14
  • Subscribers 93
  • Views 23224
archive over 18 years ago
In my current design,some wires are quite long,look like over 3000ums,diriven by a buffer,fe does not report the net has transition violation.it should be a problem for the wires are so long.these pins/path are not constrained,could encounter fix this kind thing?if so,what should i do?
Originally posted in cdnusers.org by yhu
    Based on your reply to me (Kari), I still think it sounds like a constraint is masking the transition. You didn't say if you tried a constraint file with no set_case_analysis statments.
    - Kari
    Originally posted in cdnusers.org by Kari
    Kari
    In this design,no case_analysis was set,but no set_drive and set_input_transition was set,will this be a problem?what is the default?
    if i remembered correctly, the default is 0.5ns. You can find this out by adding a set_input_transition to all the input pins with some numebr (try 0.5ns & 1.0ns) and then check the timing report (after timeDesign -postRoute)
    li siang
    Originally posted in cdnusers.org by lisiang
    Check the following line in your .conf file:
    rda_Input(ui_in_tran_delay)
    This may be what is getting used for the default. It's a good idea to set the input trans in your sdc file.
    - Kari
