  3. avoid use of certain cells within a subdesign
  • Subscribers 93
  • Views 15140
archive over 18 years ago
I've used create_library_domain+set_attribure avoid true... commands in RC to avoid instantiation of certain cells within a subdesign.
Now I'm in Encounter. What is the best way to avoid optimization to replace cells and use those I didn't want?
I've found some options
a)setOptMode -noRestruct
b)set_dont_touch on cells I don't want it to be replaced
(a) is not desirable because it's a global option and  there are modules I'd like to let Encounter to optimize
(b) is ok, but I would like to let Encounter  optmize(resize, restructu) whenever needed but just not using some types of cells.
Do you suggest any other option?
Thanks.
Originally posted in cdnusers.org by mhkataoka
    No easy to undel that in Encounter...
    One possible workAround is to:
    1- Setup your restrictive dontUse list
    2- Run a full block optimization
    3- set a dontTouch on your specific module
    4- relax your dontUse list
    5- run incremental optimization
    For the step 2, you might have to specify a path_group (Someting available in 71), if your critical path is outside your special module, to force encounter to work for path within it.
    Pat.
    Originally posted in cdnusers.org by bougantp
