  3. macro placement
  • Subscribers 94
  • Views 15558
macro placement
gops
gops over 15 years ago
 While floorplanning, how will I fix the space between two macros communicating each other. I have read somewhere that I should give sufficient space between the macros so that there won't be any issues for the router to route the nets. Is there any formula or rule of thumb for fixing the space between the macros.
gops
  • Kari
    Kari over 15 years ago
     After you do a quick floorplan, placement, and trialRoute, you can see how many nets you have in the space between your macros. This will help you figure out if you need more space or not. Floorplanning can be an iterative process - you can use planDesign to help.
