  3. how to the error "Size of cell PADI45(80000,141660) is not...
  • Subscribers 93
  • Views 922
how to the error "Size of cell PADI45(80000,141660) is not an integer multiple of its site IOSite(20,400000)"
archive over 18 years ago
hi:
   In checkdesign command, i t have the error : Size of cell PADI45(80000,141660) is not an integer multiple of its site IOSite(20,400000)"
   how i should  fixed it ?
   thanks
Originally posted in cdnusers.org by sbssdh
    Is this an areaIO? If not, do you actually have IO Sites in your floorplan that the peripheral IOs sit on? I don't believe sites are required for peripheral IOs, so you could remove them from the floorplan. In general, a macro should be an integer multiple of the site, but in the case of IO cells and other non-standard cells, the site is usually exactly the same size as the macro. Are your IO cells (PADI45) declared as CLASS PAD in the LEF? Just a few things to try...
    - Kari
    Originally posted in cdnusers.org by Kari
