  3. Passing variables to addStripe command
  • Subscribers 94
  • Views 16422
Kevin P Thomas
Kevin P Thomas over 15 years ago
Hi All
I am facing a problem during the execution of addStripe command with the variables as its arguments.
  addStripe -block_ring_top_layer_limit M3 -max_same_layer_jog_length 4 -padcore_ring_bottom_layer_limit M1 \
+                 -set_to_set_distance 1 -stacked_via_top_layer M3 -padcore_ring_top_layer_limit M3 \
+                 -spacing 2 -merge_stripes_value 0.065 -layer M2 -block_ring_bottom_layer_limit M1 \
+                 -width 2 -area {$XMIN $YMIN $XMAX $YMAX} -nets VDD -stacked_via_bottom_layer M1
If we specify the correct co-ordinates the stripes are properly.
+                 -width 2 -area {40.76 234.78 42.76 240.78} -nets VDD -stacked_via_bottom_layer M1
But while passing those coordinates using variables ,the stripes get places all over the core area.
 I am getting the below warining:-
**WARN: (ENCPP-613):    The intersection area is insufficient to fit any cut, so no via was created.
        layer: M1 & M2, size: 2.00 x 0.03 at (33.43, 858.39)
        layer: M1 & M2, size: 2.00 x 0.06 at (78.43, 572.78)
        layer: M1 & M2, size: 2.00 x 0.06 at (29.43, 603.62)
Please help in solving this issue.
  • Tongju
    Tongju over 15 years ago
    In the place of  "-area {$XMIN $YMIN $XMAX $YMAX}", try to use "-area [list $XMIN $YMIN $XMAX $YMAX]"
