  3. CPF format
  • Subscribers 95
  • Views 17345
CPF format
bharat kurra
bharat kurra over 15 years ago
Hi all,
My requirement is something like this my tile in onoff and the output ports need to be always on
Can someone help me in writing CPF for above requirement so that i can see a attribute of onoff for all the cells in the tile and always on attribute for output ports
I have written a CPF by seeing the user guide but i see a error while runnig Logical CLP
Error is something like this :
Driver Domain is onoff
Input Domain is also onoff
  • QiWang
    QiWang over 15 years ago
    Bharat, In the future, please post the blog in the low power solution area to ensure a prompt respond. It is difficult to answer your question without a picture of your design. Also, the answer is different for a soft block vs a hard block. If your design is a simple as: IN ----> i1/in ----> i1/INV ---> i1/out ---> OUT where IN/OUT are top level port. i1 is a hierarchical instance or tile and inside an inverter called INV. then the CPF can be: create_power_domain -name PD1 -instances i1 -shutoff_condition ... create_power_domain -name PD2 -default -boundary_ports {OUT IN} above will declare i1 be part of a switchable domain and IN and OUT ports are always on, as PD2 has no off condition. In this case, there is not impact if you have create_power_domain -name PD2 -default -boundary_ports { OUT IN i1/out} because in CPF a hierarchical pin like i1/out has not semantics of power domain. Its power characteristics is controlled by the leaf driver, i.e. i1/INV/Y hope I understand your question right Qi
