  3. Encounter terminated by internal (SEGV) error/signal...
  • Subscribers 95
  • Views 4532
Lamech
Lamech over 15 years ago
I was trying to load a OA cellview (loading a existing layout), Encounter dies with the message "Encounter terminated by internal (SEGV) error/signal...". The log file ends with the following line under gdb section:
 *** INTERRUPTED *** [signal 1]
18824: No such process
Any suggestions why I am getting this error? I desperately want this feature working!!
Charles
  • HariMani
    HariMani over 13 years ago
     Hi ,
     I faced a similar issue,. The segmentation issue arises when some random memory mismatch occurs when we set the variables. If the encounter exits saying this FATAL error, restart it again, it worked for me.
    Hari
